Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a maytag mtw5900tw changed lid switch but still will not agitate it buzzes and then shuts down
Anonymous
Level 2:
  • Expert 70 Answers
  • Posted on Oct 10, 2009
Anonymous
Expert
Level 2:
Answers
70
Questions
Helped
31302
Points
162
Maytag top load washer will not spin unless I push down on agitator briefly.
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
2answers
Hi. How do you get to the lid switch on a Maytag
You must remove the rear control panel housing...
Remove some clips - and then remove the basin surround.
Here is a video that will help you out without having to type out the entire instructions. It is a general instructional that covers just about all the manufacturers.
Thanks for using FixYa!!
Maytag serial #13605482QD, Model #LAT4915AAE washing machine--fills fine but will not start agitating when lid down; plastic receptacle behind soak light seems to be broken. Completed a wash cycle and...
sounds like a faulty lid switch assy. not recognizing the lid has actually been put down so for safety reasons will not start agitation. you can google that model number for faulty lid switch ( i just did) and find part numbers and all
When I shut the lid it wont start
you probably need to replace the lid switch. if you are mechanically inclined or know someone who is, you could bypass the switch and connect the wires to see if the machine will fill and agitate etc.
Will an agitator pick clothes
Do you meant pinch ??
If so - YES...
I have had several washers with agitators and pinched little tiny holes in my cloths..
So irritating..
I baught a front loader that just tumbles with no agitation..
Hope this helps !!
Please rate me good ;o)
1helpful
Washer is filled with water,,it wont drain,,nor
Sounds like a bad lid switch. When you close the top lid, there is a safety switch that closes, it is actuated by a pin attached to the lid, there will be a small hole located on top of the machine, somewhere on the perimter of the top of the tub. Could also be a bad timer.
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
1helpful
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
