''Your display environment does not support protected content playback''
I assume that you are using a TV with the Computer to watch a Blu-Ray disc using HDMI connection.
In order to play a Blu-ray Disc (BD) movie on a television, the display configuration must be set to display on the television only. Having the image set to display on the computer and the television at the same time will generate the above STOP error message "Your display environment does not support protected content playback message".
Follow this procedure to properly configure the settings
needed to play a Blu-ray Disc (BD) movie on a television.
1. Connect the Computer to the TV using an HDMI cable.
2. On the Computer, click the Start -> Control Panel -> Appearance and Personalization -> Adjust screen resolution.
3. In the Display Settings window, click the Advanced Settings button -> Intel Graphics Media Accelerator tab -> Graphics Properties button.
4. In the Intel Graphics Media Accelerator window, under Operating Mode, click the down arrow and then click to select Single Display.
5. Under Primary Device click the down arrow and then click to select Digital Television, and then OK.
6. At the Confirm the Desktop Change prompt, click the OK.
7. In the Advanced Settings window, click the OK button.
8. In the Display Settings window, click the OK button.
9. In the Control Panel window, click Hardware and Sound.
10. In the Hardware and Sound window, under Sound, click Manage audio devices.
11.In the Sound window, click to select HDMI Device, and then click the Set Default button.
12. In the Sound window, click the OK button.
13. Now close the Control Panel window.
NOTE: Also check for any update for the software you are using to play the videos and update for the Video Driver
Good Luck!!!!!!!!!!
