Freezers still make condensation like air conditioners. they have a drain line heater to keep the condensate liquid until it exits the freezer. then it goes into a drain pain that usually has the high (hot) side line running through it to evaporate the water and at the same time increase efficiency. you probably have a rusted out drain pan which you can replace. you can make one from sheet metal and just seal the corners with RTV silicone, be careful sheet metal WILL cut you badly, so wear gloves whenever handling that stuff.
Testimonial: "Thank you for the info. "
