Hmm, this is too general symptom too troubleshoot. But never mind. Printer cannot feed the paper for several reasons:
Auto sheet feeder (paper feeding mechanisme) is faulty;usually generate error message on the monitor or/and error code on LCD display
Paper end did not reach paper sensor because the paper not set properly or another material block the paper path.
To find out more about this error,please check the following article exclusively for Canon printer.
Paper feed error
Paper jam error
Source: Canon Inkjet Forum
SOURCE: Samsung ML-1651N Printer
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
SOURCE: paper feed problem
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
SOURCE: Not grabing paper to print Seem as though the roller feed is not
This will happens when the paper feeder sensor fails. Due to this when give any print or copy it wont feeds the paper you may get the error please load the paper. For this you need to contact HP Customer Support for a service if it is under warranty.
Thanks & Regards
Nandu :)
SOURCE: EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Take all the paper out,Make sure non of the paper is folded under on the stack. check the paper-feed area for debris,(papreclips, staples post it notes etc).
Check the tray and its guides are secure and it the correct positions.
Open the machine check the paper path for debris, bits of paper or anything the looks out of place.
Once you have checked and cleared everything, close uo the machine and try again.
If you are inclined, you can clean the paper rollers with alcohol.
Hope this is of some help
Ed
