BR-1180 Cd will not burn CD's. does it call for certain brand name cd? Is it something I'm simply not doing right? Does the MTK need to be on or off? I've done everything according to the manual, I think. Is ti something simple I missing here? I got a dozen or more songs ready to burn... anybody had a simular problem? Tonto
Don't know if this unit is sensitive to the type of CD, but my Phillips recorders will ONLY burn the "Music CD's" (harder to find, more expensive). Read up on the difference of regular vs Music CD's. ALSO some recorders will not burn disks rated at lower or higher rates.
You have to mixdown to the 9/10 track, cds only burn on two tracks. input to (BOUNCE) then hit BOTH REC AND PLAY buttons,record in realtime to 9/10 track. then AFTER hit the WRITE CD button on the right of the system(of the three there). And note:you HAVE TO FINALIZE THE CD before it will play on ANY COMMERCIAL SYSTEMS (car, radio, videogame systems, boomboxes,etc.) this is the breaks ,be prepared to go thru plenty of cds to get your mixes right,and keep notes to remember,unless you're already good at it.hope this helps,God Speed!
Yes same prob- I need an answer too! Do I need a new CD writer?
