My fax brother 2800 recieves the fax the first 2-3 pages come clear but once it heats up th erest of the pages come with black smurges al over, it first starts from lighter to darker, the more fak pages the darker the next one, and it will continue untill the fax cools down and the does it again after another fax or even copies.
Needs fuser replaced from the sounds of it, but may be drum.
Fuser above
Drum below
link to purchase
Common problem with this fax and others with the DR200/250 drum. Change the drum, it's shot. They have a limited shelf life. Brother's estimate of yield only works in the most favorable conditions under moderate use. Problem is, a new drum and toner cart will cost nearly as much as you paid for the machine.
trylly apreciate it, wasn not sure if it may be the drum but with your second opinion i will try that, lucky i found a site selling the drum for $55 (remanufactured) of course.
I have a similar problem with receiving faxes and printing copies. After a few acceptable copies the prints get progressively darker. if it is a drum or fuse problem where can I purchase these items at a reasonable price?
Your experience and advice will be appreciated. Thank you,
[email protected]
