"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
SOURCE: hp deskjet 656c vista version
The driver you need is located in Vista already. Please follow these instructions from HP on how to install your printer under Vista.
SOURCE: can not install hp deskjet 5650 with Vista operating system?
Drivers for this printer are already pre-installed with Vista.
Power down your PC.
Plug in the printer (wall and PC).
Startup PC - Vista will install the drivers and printer automatically.
Thanks for using fixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: hp deskjet 6122 printer
I have the correct installation software for the HP 6122, which will also install the HP Printer Assistant for checking ink levels. Contact me at:[email protected]
SOURCE: how to have free download hp deskjet D2360
The drivers for thehp deskjet D2360 ard located at:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1101015&lang=en&cc=us&prodTypeId=18972&prodSeriesId=1101113&taskId=135
After you select your OS, it will give you a list a available downloads for the printer.
SOURCE: HP Deskjet 3740 Series
Installing HP Deskjet 3740 Series is not at first to plug-in to your PC or Laptop.
Run the Utility Disc of HP Printer but Turn-Off or unplug the Printer.
If you can't install the software maybe you installer is XP compatible only, download the windows vista software of HP Printer.
www.hp.com/HP3740
