Sounds as if it won't reboot. Apart from the obvious like turning the power off and waiting, I can't think of much else to do. Have you checked to see if anything is fractionally loose? Is it covered by warranty? If so go back to the manufacturer.
HI 1 Turn off the TV so its on standby 2 Then press these keys one after another Info, Menu, Mute, Power.
When the TV turns back on you are in the Service MENU. Now press your down arrow key until you get to number 12 on the on screen options, It’s marked RESET. Push the arrow key to the right, to RESET your TV.
Next simply follow the instructions on the TV to retune your channels. OR Press D.Menu on your remote. Select Channel. Auto Store.
That should do too.
Thanks for contacting fixya.com
HI,this might just help!...
1.press D.MENU on youre tv remote
2.scroll down to SYSTEM
3.access the RESET function
4 enter 0000
5 follow on screen instructions
TV will then wipe all existing channels and start from scratch.
worked a treat on my SAMSUNG LE26R7........However i noticed my signal strength dropped significantly!!...obviously them at the other end (digital tv boffins)have been mucking about,A bit of fiddling about with my existing arial did the trick!!
Having checked my TV instructions, I was told that the 'plug and play' facility which was used with the initial installation and which retunes the TV channels was only available for selection in the TV mode not the digital.
So switch to TV and it shoudl be straightforward.
