The camera keeps on saying press the reset switch.
Try this:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
SOURCE: The camcorder keeps saying press the reset switch
no solution as yet mine did exactly the same and i lost all of my information on the disc. Suggest remove battery and open in record mode, camcorder will say error with information and ask if you like to repair disc, press yes and continue as normal!
I have the same problem at present. Everytime I switch the camera on the message appears. This problem is currently combined with the tapes door does not function properly, either it does not open or does not close.
The camera now with Panasonic service.
Same problem - "push the reset switch"
HI, I too have the same "press the resest button" problem. At first it was every time I switched it to record mode now it happens on play back mode too, so I can neither record or play back now. Has anyone out there got a solution? Taking it back foe repair is so expensive
same problem
