Hi. I have a Meile T380 drier. The on-off button won't stay on. I used to be able to press it a few times and eventually the on button would stay on. Now, that doesn't work. Any ideas what could be wrong
Re: Hi. I have a Meile T380 drier. The on-off button
There is a fuse behind the on/off switch but to get to it you need to open the top then the control panel with special tool and you can check the fuse there is another fuse on the bottom left corner of the unit behind the transformator. good luck
It is most likely a blown thermal fuse located on the blower housing next to the heating element caused by restricted exhaust vent on the drier. Check the vent and clean it out if plugged up it will not stay running.
Hi I used my drier and worked fine, went to turn it off and light stayed on and the off button would not turn off. Turned it off via the plug, now will not come back on. What is the fault , and is it easy to fix Many thanks . My tumble drier is a Login LVD7W15 Many thanks
A soft reset will clear pending errors and bring your mobile to its initial state by restoring factory settings. To do this, the shortcut is: *#7380# This function apparently works on almost all Nokia mobile phones. Hard Reset It may happen that despite having restored your mobile to factory settings, the error still exists. In this case, it is recommended that you opt for a hard reset. Enter the code: *#7370# and press Yes to confirm. Important: You should back up any important information before doing this. To perform a hard reset on a Nokia phone that won`t turn on, press simultaneously these 3 buttons: on/off + * + 3.
I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email [email protected]. We'll look forward to hearing from you.
The pressure/ temp switch on the reciever drier is what the system uses to determine if the system has enough freon. Most likley cause assuming system is properly charged. You can pull actual values through the a/c push button module. If you cannot see an erratic value your best bet is to have the system scanned for codes.
