Hi there, you do have a vertical problem, its a resistor with 100k ohms or up at vertical section, next is some capacitor with 100microfarad. try test some parts at vertical section. ty
Vertical lines on your LCD usually tells you that your screen is failing. You can do a quick verfication by plugging in an external monitor - and if the external monitor looks normal, then that ought to confirm it.
Once you have vertical lines on your screen, there's no way to get rid of them - it's pretty terminal unless you're into repairing microelectronics. For replacement screens, eBay would probably be your best bet.
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
