Fuji Finepix Z20fd Digital Camera Logo
sarah neufeld Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have some pictures that are saved on the internal memory of the camera and not on my memory card, I cant seem to get them uploaded onto the computer.. how do I do that?
Jim DuBreck
Level 3:
  • Master 578 Answers
  • Posted on Oct 12, 2009
Jim DuBreck
Master
Level 3:
Answers
578
Questions
Helped
252619
Points
1695
Remove YOUR memory card from the camera. then connect the USB cable to the camera - then to your computer.... it will see the internal memory-stored picts.
My camera says the pictures upload onto my computer but then nothing happens after that....the pictures dont upload what is the problem?
Internal Memory: 32MB
SD Card / SDHC Card (Up to 4GB support)
Possible that internal memory is empty and your are transfered zero file. Switch to external SD memory in your camera menu should take care of the problem. Get the SD card reader is your easiest option. just copy and paste the photos to my picture in your computer.
1helpful
Internal Memory full; No memory card in; Will not take pictures;
You need to get a memory card and promise to never use the internal memory again....it only causes problems as you have found out. When you get the new card follow this procedure: 1. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to format the internal memory. 2. Insert the new card and do the format thing again to prepare the new card. Happy photography!
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 2helpful
    2answers
    I have a new memory card. I cant get pictures
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    4helpful
    Save from internal memory to memory card?
    On play mode, press MENU, on PLAY tab-->COPY-->BUILD-IN->CARD, press SET,then wait until the "Busy...Please wait.. disappears.
    6helpful
    Need to put Pictures from Camera onto Memory Card
    Hi there. Here is how you do it. Go into the menu and navigate to the Copy screen. Choose an option. One is to copy pictures from the camera's internal memory to the SD card, and the other is copy from the SD card to the camera's internal memory. Then press OK. On the next screen, you have two option choices, either copy all images, or selected images. Hope that helps.
    Transferring internal memory pictures to a memory card
    Use the Copy command to copy the pictures from internal memory to memory card. See page 84 of this manual: http://www.fixya.com/support/p443879-polaroid_i532_digital_camera/manual-20448
    4helpful
    2answers
    Transferring images on camera memery onto memory card.
    I had the same problem, and I found after much playing and mostly accidental findings that I could do this by following these steps
    1. Put an SD card in the camera. Will not work otherwise
    2. Go into playback mode, where you view the pictures, button looks like an blue arrow pointing to the right
    3. Press the round 4 way controller downwards, and a menu (that I have never seen before!) appears
    4. Choose the 4th icon along on the top line and that will give you options to transfer from memory card to camera and the other way around.
    Images not uploaded
    Try uploading your pictures into Scanner/Camera wizard on your computer. It will save them into a my pictures folder under my documents. Also make sure that they're not saved on your internal memory while you have a memory card installed, otherwise when you transfer it's only going to transfer the ones off the memory card and not the internal memory.
    Top Fuji Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
