I have a Breville JK49 jug kettle which was working fine but it has now started to switch its self on off intermitently. The blue light appears when its starts to heat the water & then goes out but eventually it will boil the water but this could take up to 10-15 mins. Is this kettle beyond repair. !
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
SOURCE: kettle shuts off before boiling?
This is caused by a defective overload switch inbuilt in the kettle, sometimes the senitivity is higher than factory settings causing it to trip and reset several times before coming to boil. probably better to put up with it than going in for a costly repair.
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
SOURCE: Breville spectra kettle, light flashing- cause unknown?
It could mean that the warming element is defective; open.
SOURCE: filter for breville kettle jk155
Contact Breville on 0161 652 1211 and they will mail out one
