GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Anonymous Posted on Oct 12, 2009
Fridge makes howling noise off and on all day . It comes from the freezer compartment. It's a side by side -GSH22JFTA. Thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Oct 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1585
Points
13
Check the evaperator fan moter
Testimonial: "thanks"
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
958
Points
IT is your evaporator moter I am having to replace mine tomorrow.
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Gsh22kgrecc freezer compartment howls
Check to see if fan is loose also check to see if there is ice buildup inside and blade is hitting it
2answers
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
2helpful
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
2answers
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
3helpful
2answers
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
2helpful
Howling sound from freezer fan section
it is most likely the fan bushings that are making the noise. you can try to lube them with a light oil if you want to buy some time. but the fan motor will need to be replaced soon.
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
It is very common for the fan inside the freezer to develop a loud noise as it runs. Its in an environment that is hard on them, cold, wet. Its a small and simple motor, and you are right in believing there will be more problem in the future, as the stator is probably touching the housing. It has a sleeve type bearing, and its probably worn a little causing the shaft to wobble. Eventually it will stop completely and the freezer will get warm.
15helpful
3answers
You are correct in believing the fan is going to be a problem. The evaporator fans inside the freezer compartment are common at going bad. I believe it is due to the extreme temperature and moisture conditions inside the application. The noise is the stator or bearing equivalent going out, the speed should remain constant. It may eventually make a screeching noise upon start up, or just lock up completely. The good news is replacements are relatively cheap and easy to find. If you do replace it yourself, make sure the fan blades are blowing in the right direction. If possible, remove the old one and bring it with you to the local appliance parts supplier and he should be able to help you get the right one, it will probably be a kit of some sort with multiple mounting brackets, screws, and maybe even a couple of blades. don't let this intimidate you. Most of this you will not use.
Top Refrigerators Experts
vince
Johnny 1000
