Question about HP Color LaserJet CP4005dn Network Printer
HP Color laser jet 4700n 49.3048 service error
  • Anonymous Mar 17, 2014
    hp laser jet cp 1525nw color engin comm
    hp laser jet cp 1525nw color engin comm eroor 49
    New Friend:
  • 6 Answers
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Posted on Jul 20, 2010
    President:
  • 2,306 Answers
Thats a firmware error, could be just a false error from a document that it's unable to process or print, size, format error, etc. To clear you need to remove cables and reboot, image causing the problem could be still in the computer buffer, so you need to delete print que as well.
Posted on Oct 12, 2009
2 Suggested Answers
6ya staff
SOURCE:
Joed911
JDTec
  • 4338 Answers
SOURCE: My HP color laser jet
This is what HP says about error 49:
Control Panel Message:
49.XX.XX
PRINTER ERROR
To continue
turn off then on
Description:
A critical firmware error has occurred that
caused the processor on the formatter to
abort operation. This type of error can be
caused by invalid print commands, corrupt
data, or invalid operations. In some cases,
electrical noise in the cable can corrupt
data during transmission to the printer.
Other causes include poor-quality parallel
cables, poor-connections, or home-grown
programs. On rare occasions, the formatter
is at fault, which is usually indicated by a 79 Service Error.
Recommended Action:
1. Turn the printer off then on.
2. Press Stop to clear the print job from
the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
displays only with a certain software
program or print job, contact the
software vendor for assistance.
5. If the message persists with different
software programs and print jobs,
disconnect all of the cables to the
printer that connect it to the network or
computer.
6. Turn the printer off.
7. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM.)
8. Remove all EIO devices from the
printer.
9. Turn the printer on.
10. If the error no longer exists, install
each DIMM and EIO device one at a
time, making sure to turn the printer
off and on again as you install each
device.
11. Replace a DIMM or EIO device if you
determine that it causes the error.
12. Remember to reconnect all of the
cables that connect the printer to the
network or computer.
13. If the error persists, upgrade the
firmware compact flash card.
14. Replace the formatter and calibrate
the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 11, 2008
Error message 49.4c02
Update the firmware on the HP Color LaserJet 4700 printer to version 20091125 46.120.4 or later. This new firmware resolves the issue.
do rate the solution if helped
Nov 23, 2010 | HP 4700N Color Q7492AABA Laser Printer
How to replace image fuser kit for hp laserjet 4700n
turn off the machine. open upper front cover. remove the old fuser and insert the new one. turn on the machine and enjoy your printer with new fuser kit.
Jan 20, 2010 | HP LaserJet 4700 Printer
HP Laser Jet 4700n-Light printing on right side of paper. Removed all cartridges and toner, cleaned and recalibrated after start up. Still light printing on right side. Any suggestions??
Is the light printing the same for black and white vs color? Light printing on a side is not uncommon for these printers. It is usually caused by the laser optics getting dirty. But this usually shows up more in one color than the other. Such as something printed in yellow is fine while red is faded on one side. If the light on the right side printing is the same on all colors including black then I would suspect something with your transfer unit.
If you do notice that it us just on black or another color then it is definately time to get the laser optics cleaned.
Dec 18, 2009 | HP LaserJet 4700N Printer
HP 4700n leaves marks on prints
Either the fuser or the copy drum assembly is worn,first replace the drum, if it doesn't clear the problem, it's the fuser.
Aug 20, 2009 | HP 4700N Color Q7492AABA Laser Printer
Keeps reseting to Tray 1
Printer Defaults button? what magical land is that found in?
Here is the real solution:
In Printers and Faxes, right-click the printer
Click Printing Preferences
In Paper Source drop down, select Tray 2.
Peace!!
d(-_-)b
May 14, 2009 | HP Office Equipment & Supplies
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
HP Color LaserJet CP4005dn Network Printer Logo
31,678 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
