LG 42PX4DR 42 in. Plasma TV Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There was a power surge this a.m. where the elect shut down for a second and came back on. the only thing i had on the set was a blinking red light. i conculted the user manual where it said if an improper shutdown happens, it will take some time for the tv to power up. that was 730 this morning, it is now 315 pm. did i possibly blow a fuse? i have the model 42pf7320a
Anonymous
Level 2:
Novelist:
  • Expert 157 Answers
  • Posted on Oct 13, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
157
Questions
0
Helped
63579
Points
448
It could be a fuse but most likely the power supply got damaged. You should get the power supply checked for any defective components on it that would cause cause the TV not to turn on. Most likely damage is the capicators on the power supply in the event of a power surge.
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
2answers
Panasonic tv powerlight blinking,tv turning off and then back on, now it won't turn on at all, blinking green light goes red and it shuts off completely
My TV surname off after 5-15 minutes of use. The red light in the front blinks once every 3 seconds continuously. If I hold the power button down on the tv, it will turn on and do the same thing.
Power surge from storm. Power light turns on for 2-3 seconds and goes off. Previously had a power supply replaced 3 yrs ago. tv is approx 12-15 yrs old.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
before you rate this information or if you have questions let me know what you find.
SD TECH
Sony Bravia KDL-42V4100 42 in. LCD TV made a popping noise and then shut off and will nor turn on and red LED blinks 2 times..
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
1helpful
I own a Sony KP-51WS520 that has been down in the basement unused (unplugged) for 2 years. I decided to set up my "man cave" and went to turn on the TV. It started right up but after shutting...
Hi Hank,
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. There is no user replaceable Lamp in KP51WS520 TV.
When i turn on my tv the little red light blinks. THen the sound comes on but no picture. After a couple of seconds the red light starts blinking again and the standby light comes on and then nothing.
My kids were watching the tv when it shut off. When I got home I turned it on and green light flashed about 100 100 times now the red light flashes continuous. Tv still not coming on.
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
3helpful
RED LIGHT KEEPS BLINKING..WAS LIKE A POWER SURGE THIS MORNING..I UNPLUGED TV OFF MOSNTER SURGE PROTECTOR..CAME HOME AND PLUGED BACK IN...TV RED LIGHT TV REC STILL BLINKING
Surge protectors aren't perfect... If the surge was big enough and long enough then it can cause problems. Most manufacturers have on-board protection as well. That's not perfect either. Often the surge does nothing more than confuse the microprocessor (computer) that controls all aspects of your television. The fact that the red light is blinking means that your set is trying to protect itself. This can happen for one of two reasons. Something in the set has failed. Usually the power supply inside the set possibly also a trouble in the scan section of your set. These are normally a shop repair. The other thing is when the microprocessor is confused it will do nothing further until it's reset. To reset the processor simply unplug the set from the wall and wait 10 minutes. Plug it back in and if it works then happy viewing. If it doesn't then you will need a repair.
If is a failure caused by a failure in the grid that delivers power to your set then you are usually able to file a claim for the repairs. Contact your local power company. explain what happened. If it's their fault then usually they will pay for a repair. I know the PG&E does.
Zashiban
1helpful
3answers
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
