Question about Maytag Atlantis MAV6000 Top Load Washer
Water continues to drip into the washer when it is finished with cycle and turned off
  • 304 Answers
Water valve is located at the rear of the machine with the water hoses attached to it. Disconnect power. Remove hoses and unscrew the small angled bracket attached to the valve. Replace the valve and your problem will be solved. Part Number is 2200270. This the only possible cause for the symptom you describe.
Posted on Oct 12, 2009
    Brigadier General:
  • 4,088 Answers
Turn off the supply faucets, one at a time, to see whether the drip stops. Remove the solenoid valve hooked to (inside the machine) the outside faucet that stopped the drip and either replace the valve or try cleaning the valve with compressed air. I doesn't need to be reinstalled in the washer to see if it holds water pressure from the hose. Make sure the faucet ends of the hoses have good screens in them.
6ya staff
SOURCE:
Hoover 2010 washing machine top loading: the water continue to drip even after the cycle finish. What's the cause and how can I fix it?
if you unplug it from the wall does the dripping continue? if so the inlet valve is jammed slightly open and will need to be replaced (on the odd occasion i have had success by giving it a sharp tap) in the meantime turn the taps off when your not using the washer
Feb 06, 2017 | Hoover Washing Machines
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
When washer finishes cycle and spins out water will start dripping into the washer and will get the clothes wet if not taken out
You have a faulty water inlet valve which needs to be replaced. If it's cold water dripping into the machine then it's the cold water inlet valve.
Oct 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
When the washer finishes the spin cycle and I open it up to remove the cloths, the water continues to drip into the drum. What do I need to do to repair this problem.
It sound's like the water inlet valve is stuck open, it's located at the back of the washer, the cold and hot water hose's connect to it, you may need to replace it with a new one to fix the drip.
Apr 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
306 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
