Panasonic PT-40LC12 40" Rear Projection HDTV Logo
Posted on Oct 13, 2009
Where can you order a ballast repair kit for a Panasonic PT-60LC14 TV?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
570
Points
10helpful
4answers
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
tip
Panasonic PT60LC14 Manual Download
Download Panasonic PT-60LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-60LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-60LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
tip
I hope that helps.
on Apr 27, 2010 • Televison & Video
Panasonic PT-60LC14 Convergence Issue
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Panasonic pt-50lc13
The ballast probably needs to be repaired. A repair kit #LSUC0022 is available from Panasonic.
3answers
Where can i buy the ballast repair kit for the PT-50LC13 tv?
try these guys out
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150273671347&ssPageName=STRK:MEWA:IT&ih=005
3helpful
3answers
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <[email protected]>
Panasonic PT 40LC12 40
Wild4art Did the service center replace these ballast and the set worked for you for awhile?? Or did they say that they replaced the ballast transformers and now the set needs adD.. If its the later yes it sounds like someone misdiagnoised the set ordered the expensive transformer and now are sticking them to you even though you MAY(?) not need them. Its a hard call without seeing the set. How old is this set? if its not to old I would contact panasonic and tell them what this service center is saying and have them investigate as panasonic is very strict with there servicers. Try the # I posted or look in your owners manual for the service department.. Good Luck 800-211-PANA
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
