Question about Olympus Stylus 850SW Digital Camera
The battery died in my Olympus 850SW camera, I have been charging it but now when i put it back into the camera the LCD reads "empty battery". Help.
The battery is probably too old
Posted on Oct 15, 2009
6ya staff
SOURCE:
My new olympus stylus 850sw is not working. The flash settings do not seem to work, and all the pictures turn out either really dark, or a bright white screen. I've altered all the settings, and nothing is...
You could have a problem with the board of the camera. I hope you did not drop the camera. If what you say is happening try to restart the computer of the camera by removing the main battery. It also has a reserve battery and I suggest you remove that too. In about an hour put the batteries back and see if the camera has reset itself. If it does not work I hope you applied for the extended warranty and just send it back to the camera shop if they handle it or directly to Olympus. Good Luck
Jan 07, 2011 | Olympus Stylus 850SW Digital Camera
I have an Olympus 850sw and each time I turn it on it asks to enter the date and time. Why is that?
Most of the cameras with a date time clock have a secondary internal power source like a small watch type battery some point and shoot cameras use a storage cell which takes power from the main battery. This means when the main battery looses power the camera clock will hold a setting for about 1 day or 24 hours. To keep the camera clock set you need to keep a charge in the main battery. Here is a screen shot from the manual explaining this function.
Jan 05, 2011 | Olympus Stylus 850SW Digital Camera
My Olympus Stylus 850SW won't turn on. Thought it was a drained battery, got new battery, then thought it was my charger. Bought new charger. Battery is fully charged, camera still will not turn on.
Link
Good day,
Link above leads you to the Stylus 850SW manual-see page 62. Please make sure that you are using Olympus Lithium Ion Battery only, as this is the only battery the camera is accepting. Using exhausted battery will make the camera to turn off.
If the problem still persist, kindly contact Olympus Help desk for more details.
Regards.
Aug 05, 2010 | Cameras
Recharchable battery will not charge olympus 850sw
You can download a manual at this site.
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1365
It sounds like your battery is dead. How long have you had this camera? If the battery is not charged properly it will cause the life time to be cut in half or more. When charging these batteries you have to let them die completely before charging. This could be a major problem if your in the middle of taking pictures. I have two batteries for all my cameras that way I always have one on stand by. Hope this works. Let me know if I can help you with anything else.
JimmyC
Sep 28, 2009 | Olympus Stylus 850SW Digital Camera
Battery empty message when connecting olympus sw 1030 to laptop
Your recharged battery may be weak. May be time to replace.
If the battery power runs out while the camera is connected to a computer or printer, the image data may be lost or damaged. It is recommended that you
use the AC adapter. Do not connect or disconnect the AC adapter while the camera is connected to a computer or printer.Do not remove or load the batteries or connect or disconnect the AC adapter
while the camera is turned on. Doing so could affect the camera’s internal settings or functions.
Sep 02, 2009 | Olympus Stylus 850SW Digital Camera
After charging the battery i put it in my camersa and it reading batttery empty
This happened to me before and its because i put the battery in the charger the wrong way up. Make sure you put it in so that the side with OLYMPUS in it in big letters is facing up!
Apr 20, 2009 | Olympus Stylus 850SW Digital Camera
When i turn on camera, it says battery empty
ok this happpened to my old kodak once. actually, several times.what i ended up having to do was give it to a mechanically inclined friend to fix. as it turned out, some cable had been fried after one of the times i dropped the camera. so you can either:
  1. get rechargable batteries to save money
  2. buy a new camera
  3. contact a mechanically inclined friend/relative/co-worker
hope this helped!
Apr 04, 2009 | Olympus Stylus 850SW Digital Camera
My LCD display just randomly stopped working.
replace the battery and check out firat with brand new battery.many a times it battery problem.if still the same problem its due to lcd ic faulty on the mini circuit board.that has to replaced by a service center.
Apr 03, 2009 | Olympus Stylus 850SW Digital Camera
Olympus Stylus 850SW Digital Camera Logo
314 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
