Kenmore Oasis HE 27082 Top Load Washer Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DU error code - Kenmore Oasis HE 27082 Top Load Washer
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Oct 13, 2009
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
430193
Points
5400
The Kenmore Oasis and Whirlpool Cabrio washers are essentially the same. Following is the Whirlpool Installation and service manual for their Cabrio washers.
The DU indicates a problem with the door Un-lock mechanism. See the section on troubleshootingdU error code - 2.gif and display codes.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/dU error code on...
The F/dU is shown on the display due to Door Unlock Error in the washing machine.
In this problem check the Door Lock in the washing machine. Either the door is getting blocked or not getting locked or the door latch assembly is got cracked.it needs to be checked and replaced.
This will help. Good Luck.
on Mar 11, 2010 • Washing Machines
Beckman DU 530 spectrophotometer has monochromator error code
He's not talking about a washing machine. It's a laboratory spectrophotometer posted in the wrong section.You'll have to send it for diagnosis and repairs. Our lab's 520 gave the same error. Estimated repair: $2-5000.
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
2helpful
Hi. My washer is coding dU then F as codes.. I cant get it to shut off and unlock the door to get cloths out. The book does not have a code for dU.. PLEASE SOMEBODY HELP ME :)
Door unlock error. The machine tried 6 times to unlock the door. Must be an item of clothing jamming the door. take the bottom panel off and reach up and grab the emergency ring, GENTLY release the door amigo. Use this GUIDE for repairs
and use your tech sheet inside that base panel for error codes and diagnostics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
F35 error
D?FAILLANCE DU CONTACTEUR MANOM?TRIQUE
If after 30 seconds the control does not detect water
entering machine, the valves will be turned off and the
error code will be displayed. OR If the control has
turned the water valves on and after 8 minutes the flow
sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip,
the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Si apr?s 30 secondes le syst?me de commande n’a pas d?tect? l’entr?e d’eau
dans la machine, le syst?me ferme les ?lectrovannes et commande l’affichage du
code d’erreur. OU Si le syst?me a command? l’ouverture des ?lectrovannes
d’entr?e d’eau et si apr?s 8 minutes le capteur de d?bit a d?tect? le passage de
10,5 gallons d’eau, tandis qu’aucune manoeuvre du manocontacteur n’a ?t?
d?tect?e, le syst?me commande la fermeture des ?lectrovannes et l’affichage du
code d’erreur clignote.
Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement de
l’affichage.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check to verify that the pressure switch is
operational.
3. Replace pressure switch.
This is for an F32...there is no F35 fault code on your model according to the service manual....
10helpful
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
1helpful
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • 2helpful
    Du error code on whirlpool cabrio
    that code is for the door unlock error. is it possible that you may have tried really hard to open the units lid when it was locked? if so the door lock may have been broken. if not, then try to unplug the unit for a few minutes and try a new cycle.
    if the code comes up again then you will have to call for free service as it has a 1 year warranty for parts and labor. yes even if you broke the lid lock!!! dont worry it happens when you get something new and are not sure how it works.
    Alexander
    vince
