The 608h series unit have a variable speed pulley assy. and some have also a an ty vibration assay. fri st remove the deck belt from motor, take out the bolt engine pulley drop down remove belt, on the verbal loosen the bolt left the upper belt off and now left the center pulley up and remove the engine belt. should have the brake in lock posh ion fri st sorry. know if you have an an ty vibration pulley remove the spring and unbolt the pulley . feed the belt throw reassemble. hint have the deck in the full up posh ion for better removal. good luck
