Question about Vizio VO47L 47 in. LCD TV
We have a Vizio model # GV47LFHDTV10A. When we went to bed last night the tv was working fine. We tried to turn it on this morning and nothing. There is some power. The Vizio logo lights up and so does the control strip on the front of the unit lights up as well. But there is no picture or sound. There is just a black screen. Not a blue screen like when you didn't turn on the satellite. Also, you have to unplug the tv to turn it off. It will not turn off by touching the power on the unit or with the remote control.
    New Friend:
For the cheap guy like me who will probably do more harm than good:
Also check for the F3 Fuse on that same main input board. It is located in the upper right corner. Hard wired fuses; very small. You will see F1-F4 (F4 is empty). You can solder a replacement fuse right over it. I would recommend piggybacking the fuse with a fuse you can replace. Will need the holder and a new fuse. 6 bucks.
Doesn't solve problem, but I can go another 2 1/2 years and the wife won't blame me for screwing up the TV in the first place.
Posted on Feb 14, 2010
  • 1 more comment
  • r_to_the_k Dec 09, 2010
    Fixed my 47" GV47L for $7.18... Did the F3 Fuse bypass solution, and it worked like a champ!!! No problems since! The part that took the longest was the drive to Radio Shack!!!
  • jtothek Aug 20, 2012
    I have the same problem. You can get the part at mouser electronics online. The F3 fuse looks to be a littelfuse manufacturing number: 045101.5MRL. For those looking to repair themselves.
  • George Mar 20, 2013
    you are amazing the tv repair shop wanna charge me $ 400.00 i did with $8.00
    New Friend:
  • 13 Answers
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
  • 2 more comments
  • jg_wi Dec 23, 2010
    I have the same condition. What parts did you get at Radio Shack to fix it? Thanks. jg
  • nevinl Dec 31, 2010
    I Fixed my 47" GV47L for under $12... By passed the F3 Fuse, and it worked like a champ!!! No problems since!
    Hardest part for me was the soldering since I have jittery hands and not much soldering experience.
    Need a 15 amp fuse and fuse holder. I got mine at radio shack and used an auto inline fuse holder (see picture) others online gave me this info and I followed their directions to success!
  • cvargas24 Jan 04, 2011
    we need help on bypassing the f3 fuse please we are having the same issues can you help please!
6ya staff
SOURCE:
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Black screen with sound
My 47" LCD Smart T.V. was working fine last night. I got up this morning and I have sound but no picture. The VIZIO icon lights up as usual but I get no picture, only sound. From the time I turned it on, nothing appeared on the screen. I have already tried unplugging it for a while and still nothing.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Dec 14, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Sep 26, 2009 | Samsung 50 in. Plasma TV
Viewsonic problem
Have you checked the SCART leads?
Usually seems to be the cause of this kind of thing.
Nov 07, 2008 | Televison & Video
Vizio vp50
Maybe the scart has gone or it is not in properly hope this helps..
Jan 22, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Mitsubishi WD-62327 no pix and no sound
First do the self diagnosis test, search threads here or go to www.ctechnicians.com
Dec 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Vizio VO47L 47 in. LCD TV Logo
4,368 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
