There should be a way to select "send by email" when you finish scanning a document on the computer. Or you can usually attach the document to your email from the program you use to send emails. You may have to save the document first.
Place your document face down on the scanner bed. Press the button that starts the scanning process depending on your scanner or printer.
Save the scanned file to your computer by clicking "File" in the menu bar at the top of the screen, then choose "Save as." Choose the folder in which you wish to save the document from the drop-down menu in the window that popped up during the saving process. Choose a name for the document, then click "Save."
Sign on to your email account, then choose "New" or "Compose" to start a new email message. Click on "Attachments" or "Attach." Wait for a new window to pop up, then choose the file you scanned from the folder where you saved the document.
Wait a few seconds for the file to attach, compose your email message, then click "Send." Your scanned document will now be sent to the recipient's email address.
Place your document in the scanner and choose a low resolution. Although scanners allow you to choose a high resolution, that feature is better suited for transferring photographs into your computer for editing. For documents, a resolution of 100 dpi (dots per inch) is a good choice.
Open your computer's Control Panel and select the "Scanners and Cameras" icon to open the scanner wizard. Follow the instructions to choose a location to save your scanned document. Create a new folder on your desktop, making it easy to locate the file later. Scan as many documents as needed to this folder.
Use your email account and create a new message, inserting your intended recipient's email address in the "Send to" field. You must type in the email address exactly.
Look at the top of your email window to find the "Insert" menu. When you click on it, a drop-down menu will appear, select the "Attach a File" option and choose the location of your document.
Highlight the desired document in the folder and double-click on it to attach it to your email message. Check to be sure the document attaches by looking for the file name in the "Attach" box above your text.
Repeat Steps 1 to 5 if you need to attach more documents. Send your email as usual.
When you scan a doc to email, it will open either outlook express/Windows live mail or outlook and use that to send your email. If you have not configured either of these programs on your pc then it cannot send anything. the way around this is to scan the docs into your say My Documents/Documents folder and then attach them to your email as attchments.
If I'm understanding your question, this printer can print, fax and scan. So, you can scan an item, save in a file and send as an attachment in an Email. Hope this helps.
Hello, my name is Chris. Scan them to your computer. After they have been scanned, locate the scanned document. Go into your email, compose new message, and than look for an ( add attachment button befor you sent the email.) Locate the document you wish to send in email in the box that appears, and attach. than send.
When you scan a document it must be scanned with OCR software. The default scanning method will scan a document as a picture, not a document with letters and words. The OCR software will recognize the letters and put the scanned document in the proper format to open it with MS Word. The software that you scan with should have a setting for OCR, read your instructions or help files to get the details if you can not find them very easy in the software you use for scanning. .
The problem with using Outlook may be that you have not set it up properly to get your emails from your email server. You do not need to use Outlook or Outlook express to send any documents, you can use your web based email server if you like, but you can use Outlook Express as well. You just need to add the document to send as an attachment to the email.
To set up Outlook Express to get your email, you must first find out what the POP3 and SMTP setting you must use. You can get that information from your email provider, it is different for every email provider. Then you go to the "File" menu at the top left of Outlook Express and select "Identities" and select "Add New Identity" and from there you will go thru a wizard to guide you thru the process of setting up your email client. Just make sure you have the POP3 and SMTP settings available for you to put into Outlook Express when prompted to in the wizard.
