The wash is about halfway through and then the machine stopped washing and started beeping and the display says "pump blocked".
TURN OFF MACHINE AND UNPLUG THEN DO THE FOLLOWING:
Open the pump filter cover:
Remove and uncap drainage hose to empty detergent and then replace the cap.
Unscrew the filter and clean it, inspect the filter cavity inside the machine for matter that might be blocking it. Check the waste hose that leads out of the machine to see if there is a restriction somewere.
