If, by coil, you are referring to the ignition armature and since you
didn't specify what brand of engine you have I will give you
instructions for Briggs: ((The instructions are similar with MOST
engines with a few variances.))
Disconnect the spark plug
wire from the spark plug, remove the blower housing from the top of the
engine (That is the half round/half square metal cover on top of your
engine, this will give you access to the ignition armature:
Installing And Adjusting A New Ignition Armature
An ignition armature must be set at a precise distance from the flywheel. Ask your Briggs & Stratton Authorized Dealer or consult our Engine Check Chart for
the proper gap for your engine. Common armature gap ranges are .006-
.010" and .010 - .014". Armatures are often packaged with a shim
to assist in setting the gap. Microfiche or index cards of the
proper thickness also work well.
How to Replace a C.O.P. Type Ignition Coil?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-cop-type-ignition-coil.html
How to Replace an Ignition Coil
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-ignition-coil.html
How to Replace an Ignition Control Unit
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-ignition-control-unit.html
How to Replace an Ignition Wire Set
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-ignition-wire-set.html
How to Test Ignition Coil?
http://schematicsdiagram.blogspot.com/2011/12/how-to-test-ignition-coil.html
Engine not getting spark from distributor?
http://schematicsdiagram.blogspot.com/2011/12/engine-not-getting-spark-from.html
Cost to replace ignition coil?
http://technoanswers.blogspot.com/2012/01/cost-to-replace-ignition-coil.html
Ignition locked up on Mercury Villager?
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html
How to replace ignition coil for Toyota rav4?
http://technoanswers.blogspot.in/2012/02/how-to-replace-ignition-coil-for-toyota.html
These details will help.
Thanks.
