Clarke Power Products Mig/Fluxcore 180En 220V Logo
Posted on Oct 16, 2009
Block for the ground clamp and the gun to hook up to on a 180 en clarke mig welder is burnt up can you help me?
paul wright
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Oct 17, 2009
paul  wright
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
8770
Points
31
Hi if you want to mail me some pics through i have various sockets etc that will replace this. [email protected]
1helpful
Is there a connection for gas to mig weld on a Clarke 6440 flux welder
No. Not with the spool up on the gun. It is one of the few flux core specific welders.
This is not to say you could not try. the hard part is the plumbing between the gun and the main box. If you can get that figured out it would otherwise be the same components as other MIG welders.
I need clarke mig welder partes for the gun on a 130en. I can't find them any place, can you help me find them. Thank you.
Hi:
It will be better to adapt a new gun. Go to your nearest Praxair (www.praxair.com) store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at ALL welding stores and it's a cheap gun also.
1helpful
4answers
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Getting lots of splatter weld will not hold
Check polarity of machine.
Solid wire with gas assist will need straight polarity ground clamp to negative side.
Flux core wire no gas, need reverse polarity; ground cable to positive side.
Everything comes on and the wire feeds. However it
Check that your ground clamp is connected to the work piece securely.
3helpful
2answers
Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Clarke weld 85 en welds when gun trigger is not operated
hello make sure its not set on auto or the pin inside the set is not bent good luck
shaun
2answers
Welder not welding
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Top Clarke Power Products Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
