Question about Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer
Kyocera FS4020DN is showing paper jam in display with directions of how to resolve this issue. There is NO jam-and directions have been followed numerous times-printer has been restarted -numerous times-but screen always reverts to paper jam
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
After removing paper tray, above the paper tray slot, on the bottom of unit, left side, is a green tab. Pull metal flap down, remove paper, and your in business. That is just my experience with my friends unit.
Posted on Oct 20, 2014
  • Tendai Thomsen
    Tendai Thomsen Feb 01, 2019
    very useful, could not find the paper
Tried all the above including fully stripping down the printer but it kept showing jam in cassette 1 although I knew there was definitely nothing trapped inside. I placed paper into the front pull down feed to see if would work from there and 'Hey Presto' it reset itself.
Posted on Oct 15, 2019
6ya staff
SOURCE:
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: Kyocera C5015N paper jam can't remove
I guess it is stuck in the Fuser at the back, concertinaed at the exit claws,
Remove paper tray complete, pull green handle right side where paper tray came out, another tray will stop 3/4 of way out, there is a tab on each side, that you press in, one on each side of the rail, these are the bits stopping tray from coming out all the way, once you have the "process tray" removed you can see in to the fuser entry side and they may be enough to grab and remove it. If not unplug, top and sides off, unplug 2 cables, remove fuser screws and remove fuser.
Posted on Dec 17, 2008
Anonymous
  • 56 Answers
SOURCE: Kyocera Printer FS-1800 plus
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Posted on Nov 29, 2007
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Posted on Jun 12, 2008
IrishDruid
Swilin Sampson
  • 2712 Answers
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 11, 2008
NitrusInc
NitrusInc
  • 326 Answers
SOURCE: I have a Dell W5300 printer. After removing all
Have you attempted leaving the printer unplugged (if possible in the on position) for a period of 5-10 Minutes?
Posted on Apr 13, 2009
Why HP c4480 showes paper jam error but no paper jam and not printing
Please access the steps that should resolve by clicking on the link Paper Jam Message Displays on the All in One
If issue still persists please contact HP for further assistance as it could be a printer hardware.
Aug 02, 2014 | HP PhotoSmart C4480 All-in-One Printer ...
FS-4020DN "Paper Jam Deplexer"
check for jamed paper above the paper tray in the duplex unit.
=remove tray
=move green lever and open duplex unit
=remove jam
Jun 27, 2014 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
The display on the Kyocera FS-4020 Printer says "No Multi Copies, Press Go" what causes this and how to fix it? thanks
Go to menu.
scroll down to device common
scroll right
scroll down to ram disk
if it shows off:
press ok button now question mark blinking
scroll down to on
press ok button
press menu button
Oct 08, 2013 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
May 28, 2010 | Kyocera FS-3900 DTN MONO LASER PRINTER
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The 2022SP gives me a jam indication but there is no paper jammed.
If it shows it all the time there is paper or at least something, if it jams on the first copy paper size or paper direction issue. Does the display show the paper size and direction correctly? All drawers fail? May have torn paper behind the cover that the bypass tray sits on. -Carl
Jul 08, 2009 | Ricoh Office Equipment & Supplies
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera FS4020DN (A4) Workgroup Mono Laser (Duplex+Networked) 128MB 1200dpi 45ppm 600 Sheet Printer Logo
3,546 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
