I need a Manual for my Medion external hard drive(200GB) msn 5001 6451 item # 6633 200 GB capacity Ultra ATA/100 Hard Drive 7,200 rpm 8.9 millisecond thanks shelby
  • Anonymous May 11, 2010
    Most external hard drive manuals are very tiny, containing little more info than what you listed.
  • 6 Answers
6ya staff
SOURCE:
I dont have a hard div
Hard Drive
Oct 21, 2012 | Dell Dimension 2400 PC Desktop
After formatting my PC then also showing the hard disk failure error and telling to backup all programs. so what to do?
Buy a new hard drive, and start over.
www.newegg.com You want a 3.5 ATA (not SATA) hard drive somewhere around 500 GB 7200 RPM not 5400 RPM. Something like: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136109
Jun 10, 2011 | Seagate Barracuda 7200.10 320 GB ATA-100...
Need to know the capacity of A Maxtor internal drive SN:A60PVPVC Ndl:91303D6
The 13 GB Maxtor 91303D6 internal 5400 RPM hard drive can be connected via IDE. This 3.5" drive is designed for use with Windows. The 91303D6 is a drive with 512 KB of cache.
13GB EIDE ULTRA DMA/33 3.5LP 5400RPM
Aug 08, 2010 | Maxtor Hard Drive
What type of drive is st380011a is called
This drive is an Ultra ATA drive. It requires an IDE connection to the motherboard.
Here are the specs:
ST-380011A
Barracuda 7200.7
FORMATTED CAPACITY (GB) __________________80
ACTUATOR TYPE ____________________________VOICE COIL
CYLINDERS __PHYSICAL______________________
HEADS ______PHYSICAL______________________2
DISCS (3.5 in) ___________________________1
MEDIA TYPE _______________________________THIN FILM
HEAD TYPE ________________________________GMR
RECORDING METHOD _________________________EPRML 16/17 ZBR
INTERNAL TRANSFER RATE (Mbytes/sec) ______up to 85.4
SUSTAINED TRANSFER RATE (MB/sec)__________up to 58
EXTERNAL TRANSFER RATE (Mbytes/sec) ______up to 100
PIO/DMA/UDMA MODE (max) __________________4/2/5
SPINDLE SPEED (RPM) ______________________7200
AVERAGE LATENCY (mSEC) ___________________4.16
BUFFER ___________________________________2MB
Read/Write Multiple, Read Look-Ahead,
Multi-Segmented
INTERFACE ________________________________Ultra ATA/100
SECTORS PER DRIVE (LBA mode) _____________156,301,488
TPI (TRACKS PER INCH) ____________________94,600
BPI (KBITS PER INCH) _____________________up to 595,000
AVERAGE ACCESS (ms seek/read/write) ______/8.5/9.5
SINGLE TRACK SEEK (ms seek/read/write) ___/<1.0/<1.2
MAX FULL SEEK (ms seek/read/write) _______//
MTBF (power-on hours) Office _____________600,000
SHOCK (G's, 11ms/2ms):
operating (Read/Write) __________/63
abnormal ________________________
nonoperating ____________________/350
ACOUSTICS (bels)
fluid bearing (typ/max-quiet/max-perf) _<2.2//3.5
POWER DISSIPATION (watts) ________________
POWER REQUIREMENTS: +12V START-UP (amps) _2.8
POWER MANAGEMENT (Watts):
ACTIVE _______________12.5
IDLE _________________7.5
STANDBY (typ/max) ____0.9/
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Oct 09, 2009 | Computers & Internet
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Sep 30, 2009 | Compaq Presario 1.8GHz Mobile AMD SempronT...
I need to replace the dead hard drive in my dell dimension 4500s. Current dead drive is a 40GB Ultra ATA-100 (7200 RPM). Can someone tell me what I can upgrade to. I think I have the flat data cable so it...
You can replace the hard drive with a larger capacity hard drive. Best bet would be a 250GB .
Hard drive have come down in prices, you should be able to get a 250 GB. for less then $100.
Western Digital ansd Seagate are my preference.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | Dell Dimension 4500 PC Desktop
Whats the largest replaement HD I can put in my Presario
The HD capacity is defined by the bios software in the computer, if HP/Compaq tells you that 80Gb is the maximum capacity, then I think you should believe them, after all they should be the first one interested in selling more high price products, go for the 80Gb is .
May 03, 2008 | Computers & Internet
Computers & Internet Logo
134 people viewed this question
Ekse
Marvin
Marvin
