Re: Need a color wheel for RCA Scenium HD50LPW165 50 in...
That color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels. http://servicemanuals.vstore.ca/
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Need to have the color wheel rebuilt. New ones are no longer available for your model. You can get the color wheel rebuilt at the following link under color wheels. http://servicemanuals.vstore.ca/
It sounds like it is the Color Wheel. I do not think you can get the Color Wheel separate from the Optical Engine like you can with Samsung. RCA is very tight with there parts like that. Because you have to get the whole
Engine Assy, cost would be too much in my opinion to invest into it. The part cost approx 800.00 the last time I checked on one.
Good Luck,
I Hope this helped,
Skyassoc
Its the color wheel assy. Its changing speed due to worn bearings. You may also hear a hum coming from the rear of the TV. Seek an RCA authorized service center to resolve this.
color in a dlp is controled by the color wheel.. this may be an indication of a pending color wheel failure. is the produceing a lound whining noise. this could be other problems but this is my first instinct on the symptoms given
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
