After a power outage, the digital and analog timer and clock did not come back on. Is there a ciruit breaker or fuse I can replace behind the control panel?
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
I had a Wolf 30F wall oven with a similar problem after power outage. It wouldnt stop beeping with error message related to temperature control. My solution was to turn power of at circuit panel, then reset by pressing and holding the clear button for 5 seconds.
Also note: in my case I had to close the display before switching the panel off. When I tried to the reset process with the panel showing, it wouldn\'t reset.
To reset other various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set the 12-hour clock to the current time of day. It may need to be reset after a prolonged power failure. The clock is visible on the control panel during all modes. If the upper oven timer is set, the clock will not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to set current time of day.
3) Touch CLOCK or ENTER to start clock.
24-HOUR CLOCK
The time-of-day clock can be changed from a 12-hour clock to a 24-hour clock. After the clock has been set, touch TEMPERATURE for three seconds, touch CLOCK, and then touch ENTER. Follow the same sequence to change back to the standard 12-hour clock setting.
Fahrenheit to Celsius
The oven can be changed from Fahrenheit (°F) temperature to Celsius (°C).
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Have you checked your breaker box? It could be that the breaker for the range popped to the off position. If the breaker is still on, try carefully unplugging the range, leaving it unplugged for a few minutes, then plugging it back in.
Yes you must unplug this stove wait for 5 minutes and the plug it back up, push the off button and this should reset the oven, if that does not work the circuit breaker has been tripped, it may look to be in the on postition, but you will need to move to the off postion and back to the on postion this should correct the problem
