Mitsubishi WD-62531 Projection Television Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1346
Points
I have a mitsubishi wd-62531 modle i replaced the buib with a phillips bulb wich the salesman says that my old bulb crosses over too now the picture seems to be to dark....could the bulb be not bight enough
Anonymous
Level 3:
President:
  • Master 1,284 Answers
  • Posted on Oct 17, 2009
Anonymous
Master
Level 3:
President:
Answers
1284
Questions
Helped
498379
Points
3271
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
I have a 62 inch mitsuibishi dlp you hear the sound but the picture is off were can i buy a wd-62531 lamp cartridge
Hi
Thanks for using FixYa. You can buy the lamp from this link:
Mitsubishi wd-62531 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
3answers
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL [email protected]
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
2helpful
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
3helpful
2answers
RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Just replaced bulb two days ago and now theres no picture
there could be a couple of things causing thie, make sure the lamp is all the way plugged in, make sure the lamp door is on and completily closed, also if a fan is stuck and cant spin, also the ballast can cause this, that is the small board that lights the lamp
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
