Rosewill 19" 12MS DVI R911E LCD Monitor Logo
Posted on Dec 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FLOATING BLOCK I HAVE A ATTENTION INPUT NOT SUPPORTED BLOCK THAT FLOATS AROUND ON MY SCREEN I CAN'T GET RID OF...I KNOW IT SOUNDS STUPID /CAN YOU TELL ME WHAT INPUT ITS TALKING ABOUT????? OR HOW TO RID IT???
Anonymous
Level 2:
Champion:
  • Expert 238 Answers
  • Posted on Dec 30, 2007
Anonymous
Expert
Level 2:
Champion:
Answers
238
Questions
Helped
117816
Points
358
Hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1135
Points
Turn on your computer. After Windows is on, click - Start -Control panel - Display - Setting - Screen Resolution (set to 1280 x 1024). then click ok.
Your floating box will gone.
I got the same problem and got the solution from [email protected].
Hope this will help you.
Ringo
I just hooked up one of your monitors and there is a sign floating on the screen that says "attention input not supported" what do I do?
try lowering your resolution and see if it goes away.. start with low VGA and move up the list of supported values.. it sounds like a mismatch. also check your geometry (16:9 or 4:3 for example.. it is hangs off the screen it will give an error like that.
1helpful
How can I tell if a WM48 Zoeller Sump pump is operational. It appears the water level is over the float.
Depending on the sensitivity of the float switch you may find that the float must be completely upside-down for the pump to turn on. The easiest way to check if the pump works is grab the float by hand and hold it in the inverted position - if your pump kicks in and starts pumping you know the pump itself works and you may want to adjust your float (I use tie-straps around the handle and around the float cord to artificially shorten the float). If your pump does not pump water when the float is inverted try shaking the float to see if the inner switch is stuck. Hope that helps.
1helpful
Floating box telling me to adjust to recommended screen resolution which is correct, can't get rid of floating box on a blank screen
restart the computer immediatly press f 8 and press frequently f 8 untill menu appears then highlight on "enable vga mode" and press enter your problem will be solved
1helpful
Input not supported - floating gray message Win 7
You haven't specified what monitor you use but the gray message is most likely due to your screen not being able to handle the high resolution. Try setting it to a resolution below 1600 x 1200.
Best wishes,
Graemevm
My laptop got broke, i'm using a small flatscreen monitor plugged into the back. a screen says "ATTENTION INPUT NOT SUPPORTED" just keeps floating around the screen. i don't know how to fix it
Start in safe mode and change the resolution to 1024x768 and 60Hz refresh rate. Restart and reset the resolution at the native of your display and 60Hz refresh.
Floating box
erm......reduce your graphic card output.
Input not supported is floating round my monitor screen how do i get rid of it
You probably need to change the resolution setting in your computer display settings to a setting that is supported by the monitor.
Your resolution setting right now is probably too high to be recognized by the monitor.
1440x900 should be the resolution setting for an AL1916w if your video card will allow that setting
Fran
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
3helpful
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Top Rosewill Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
