I know where your going and its a good thought
read your compressor, it will label the start up amp,
it may even be on the model label
it will give you the rated amps and the start up amps
this is current draw to run
as well as start up a stopped motor
depending on the age
most units use about
short of that use a 3x method
if it has the run amp x3 is startup
then read your surge protector if its rated higher than the amps needed to start the unit
then you should be fine
i will say most SP are rated at 15amps
my freezer is rated at 18amperes
SOURCE: when plugged, kenmore freezer shorts the surge protector and outl
if thats the case should be an apparent wire off, somethings shorting directly to ground. the chest freezer has all of its wiring behind the access panel on the side of unit , no other wires in machine id look right there for something obvious
SOURCE: when plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
