Question about Vizio Gallevia GV42LF 42 in. LCD Television
The LCD screen is dark with no sound or picture when turned on.
The LCD screen is dark with no sound or picture when the Vizio is turned on. The Vizio logo front light display turns on along with the highlighted menu touch display (volume -, +, channel -,+ and on/off). This touch display remains permanently on instead of fading out like it normally does. We have checked and secured all of the cords, hdmi cables and all were connected correctly. We have unplugged the VIZIO for 24 hours and turned it back on today and still to no avail no picture is displayed or sound comes through.
Help! What do you recommend as our first initial check or action?
    New Friend:
  • 13 Answers
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
6ya staff
SOURCE:
Screen goes dark after 5 minutes with sound
Could be the ballast boards for the white light.
Jan 04, 2014 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Vizio LCD dark screen and picture is flickering flashing
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
Nov 25, 2011 | Vizio 42 in. LCD TV
Vizio HDMI HDTVmodel VW48LHDTV10A TV sound went out and the picture got dark from outside of the screen
The inverter board is common on this set to go out, once dark then you can use a flashlight to determine that it is bad, 2 in away from screen and you should see the picture in background, the sound is something else, it will be located on the main video board, look for bad caps bulging out.
Jan 23, 2011 | Vizio VW42LF 42 in. LCD HDTV
My Vizio VT420M LCD TV has for several months has changed to a dark screen while viewing without any other problems. We always hit "power/cable" on the HD cable box and it would immediately come...
Now the tv u turn on u have a flashes of a picture only few sec. and died have sound left only?Yes,than the 2 long boards call the LCD inverter boards are the causes and the problems.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter board for the replacement.
Jan 15, 2011 | Vizio VT420M LCD TV
Tv would seem to lose connection ... the screen picture would go"in and out" and then dark, and then come back on. Now the TV won't "turn on" even though the power indicator light is on.
Now,tv turn on have flashes picture few sec.dies and stiill have sound?Yes,than 1 or 2 a long LCD inverter boards are dead. Those 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.No picture or sound at all?The Tuner board is dead,that the board,where the incomming broscasting signal cable plug into it dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards or the Tunner board for the replacement.
Sep 19, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Mar 11, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 picture too dark
Bring it back as you can't get parts for Vizio.
Jun 06, 2008 | Vizio L32 32 in. LCD HDTV
Vizio Gallevia GV42LF 42 in. LCD Television Logo
1,824 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
