Pull the starter rope and observe the ON/OFF switch. Does it flash as the engine spins? If so, you have found the problem! The flashing light in the switch indicates the engine oil is low. Add engine oil as needed to reset the AUTO-SHUTDOWN feature and it will run again. (If everything else is healthy.)
If this does not resolve the issue, reply to this post using the "Add Comments" option and we can further diagnose it.
Hope this helps,
Dolf-
