I have a sony kdf-50e2000 i replace the lamp last week. it took an hour because i kept getting the red light blinking 3 times. it stayed on for a week and now i am getting the red light 3 times. I get this even if i put the old lamp in.
Hi, Yes, if you have not replaced the lamp since you purchased this TV. Lamps usually last about 6000 hours. I've seen lamps last much longer than 6000Hrs, it all depends on the usage. Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb. If the TV is few years old then the Lamp may be bad.
HOW MANY TIMES IS THE RED LED BLINKING? IF IT IS BLINKING 3 TIMES MAKE SURE THAT THE LAMP DOOR YOU TOOK OFF TO CHANGE THE LAMP IS INSTALLED BACK ONTO THE TV AND IS SECURE.
orcording to service manual a blink of 3 indicates a loose lamp door or a inproperly seated lamp....have you recently replace the lamp? and this cound also mean the lamp is begining to fail. reseat the lamp and check the door. make sure the air vents are cleared
Hi, Question shows tv is Sony KDF-60WF655. Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen. Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure. Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem. Did you replaced its lamp in last 2-3 years? Thanks.
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
If this is a Sony dlp then check the lamp door for warp, if this is not a Sony need model and brand. Or if it is a Sony but not a DLP then still need model.
bad lamp driver, if you have already replaced the lamp. If not, try replacing the lamp WITH AN ORIGINAL SONY LAMP!. Don't waste time with cheap replacements, you get what you pay for.
