A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Single Blinking Light means it is charging, eventually the top green light will start blinking to show that it is half way charged. If both lights blink at the same time repeatedly this means there is something wrong and the charger is not charging the batteries.
If you look on the charger there should be a flashing codes should be explained depending on the type of flashes. Very fast flashes, means bad battery.
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
