Question about Toshiba 52HM95 52" HDTV Projection Television
I can not get the picture to fit the screen. When I watch sports channels I can not usually see the scoores at the top or bottom of the screen.
    Novelist:
  • 157 Answers
Check to see if you are in a zoom mode. There should be a pic size button on the remote, it can also be adjusted in the menu and cycle until you get either AUTO or Standard zoom. If this does not fix it, the light engine will need to be replaced.
Posted on Nov 11, 2009
6ya staff
SOURCE:
Top and bottom of screen are cut off how do we adjust to get screen to fit
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Mar 07, 2011 | Panasonic PT-53WX54 53" Rear Projection...
Picture is to big for screen and can't see the writing at the top or bottom? What does the touch focus do, as we have NO Manual I can't get the picture to fit the screen. I think it is just an adjustment...
I don't Know what TV you have so I can't be specific. Usually there is a format button on your remote control. If you have one that's what you want to change.
Feb 27, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The top of my picture is cut off.
Change the video output to wide screen
Oct 15, 2009 | Sony Televison & Video
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 16, 2017 | Mito Car Audio & Video
Horizontal screen size
will probably have to take to service center. will need to get into service menu and nedd serive diagram.
Mar 10, 2008 | Daewoo DTQ-25S3FC 25" TV
High Definition Channels leave bar on top and bottom
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Feb 17, 2008 | LG 50PX4DR 50 in. Plasma TV
Unable to see scores
you have to hit aspect on the remote until it fits the screen right
Jan 14, 2008 | Hitachi 51G500 51" Rear Projection...
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Dec 30, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
