Question about Dell Optiplex GX280 (99301) Motherboard
Hi.Same problem.GX280small form factor.Power on
Hi.I got same problem around same time as yours;.GX280 Small Mini Tower power on black screen.The heat sink fan sounds like a jet on takeoff. Does not boot at all. The board examined by a Chip level engineer but could not find the fault at all the voltages/signals on the board showed OK in the oscilloscope. Any help will highly appreciated.
  • 86 Answers
check your power supply, if it is powerfull enough to feed your card.
Posted on Oct 19, 2009
Anonymous
SOURCE:
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
Optiplex gx820 can i connect 300 watt power supply
You listed GX820 and GX260.
I am assuming you meant the GX260.
There are three varieties of the Gx260.
1) The SFF (Small Form Factor) power supplies can be replaced, but I know of no upgrades for these.
2) For the SDT (Small Desk Top), you can get up to a 270 (best I have seen).
Example of where to get one.
http://www.atxpowersupplies.com/180-watt-dell-power-supply-1n405.php?psu=1N405-GX260SmallDesktop
For the Mini Tower, here is an example of a 400W replacement. There may be others for this model.
http://www.cputopia.com/dell-400w-dell-optiplex-gx260.html
I have a GX280 Mini Tower and recently upgraded my PSU to one very similar to the one above.
Feb 21, 2011 | Dell OptiPlex GX260 PC Desktop
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
What is the most memory l can put in my dell optiplex gx 280 desktop ,l have 512 in it now
For mini-tower and Desktop
You should have 4 slots.
4GB is the max if you replace all the sticks.
For gx280 SFF (Small Form Factor)
You should have 2 slots.
2GB is the max if you replace all the sticks.
Nov 17, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Black screen.High noise from cpu.fan
Addboat,
I have wasted enough time in Dell community for exactly the same problem. Even a link mentioned by Move_n_man above, on 8 Oct. 09 refers to my posting in Dell community. Its nothing but a crashed bios and unfortunately theres none who could tell how to flush the bios and reload fresh bios in the bios chip when computer does not boot.
Dell is in no mood to help! So do the so called experts of the Dell community.
Sqn. Ldr. Raman K Jhanjee (Retd)
Sep 23, 2009 | Dell Optiplex GX280 (99301) Motherboard
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Installing a sound card into my Optiplex GX260
Hi
OptiPlex GX260 can be Small Form-Factor, Small Desktop or Small Mini-Tower. Compatibility with PCline 5.1 PCI depends on the profile of the PCI Card and the Profile of your OptiPlex.
GX260 Small Form-Factor is compatible with Low-Profile PCI Cards only. GX260 Small Desktop and Small Mini-Tower are compatible with standard PCI Cards. (Small Mini-Tower however uses a PCI Cage).
Check OptiPlex GX260 Systems User's Guide - http://support.euro.dell.com/support/edocs/systems/opgx260/en/ug/index.htm
From here you visualize the 3 form factors. Also there is info and steps to install PCI cards.
NB:
1. Generally, upmarket PCI cards are standard height. Some manufactures supply a metal piece to allow it to be used in Low-Profile or Standard Profile.
2. Driver software needs to be installed after the hardware is installed.
Mike
Apr 12, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
219 people viewed this question
Ekse
Thomas F. Schneider
