Keurig Special Edition B60 Coffee Maker Logo
Posted on Oct 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to pack my special edition keurig. It is
I need to pack my special edition keurig. It is too heavy with all the water in the tank. How do I empty ALL the water from the machine so that it can be packed?
Eddie Tam
Level 3:
  • Master 294 Answers
  • Posted on Feb 03, 2016
Eddie Tam
Master
Level 3:
Answers
294
Questions
0
Helped
216853
Points
3049
12/03/2015: I just talked to the Keurig machine technical support. They said the internal reservoir can not be drained and that the amount of water that exists inside it will eventually evaporate. Tech support says: As long as you drain the attachable reservoir tank, you should be okay.
  • I would try to do a cup of hot water and then immediately after dispensing, turn off the machine before it can draw in reserve water
  • Make sure you wait at least 30 minutes for the water to cool down inside the machine before trying to remove it or you might get burned from the water coming out of it.
  • Unplug the machine before proceeding
  1. Open the K-cup dispenser
  2. Turn the Keurig machine upside down at an angle so that the water comes out of the nozzle, where the K-cup sits
  3. Softly jostle the machine until the water starts to trickle out
  4. don't get discouraged if not all the water drains out. just do your best and be satisfied with it.
  5. pack it upright in a box, make sure the machine is properly cushioned on all sides so that it doesn't get damaged if accidentally tilted, bumped, etc
  6. mark the top of the box "this side up"
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Oct 18, 2009
Anonymous
Expert
Level 2:
Answers
83
Questions
0
Helped
38496
Points
249
I would just continue to brew the water out (without coffee) into cups until the water is completely used up.
  • Rosemary Cagle
    Rosemary Cagle Dec 28, 2013
    The water will not brew out without more water coming in from the outer tank so this doesn't help.
How to clean keurig
It might be time to clean your keurig. Fill the water tank with vinegar and run through about 5-6 glasses leaving time in between to let the vinegar clean. After running all of the vinegar through it should be brewing regularly again.
I get the message saying "prime" and the light on the bottom of water tank is blinking even if there are full tank of water
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
13helpful
2answers
My Keurig B60 (special edition) won't stay on. When you turn on the power it runs for about 30 seconds then turns off (the auto-off feature is not turned on).
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
1helpful
Missing black portion pack assembly housing
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
