Toshiba Satellite A135-S4427 Notebook Logo
Anonymous Posted on Oct 18, 2009
Red Line down LCD screen
I have a Toshiba A135-S4427 laptop. All of a sudden, a thin red line about 1 or 2px wide showed up going straight down the screen. If the angle of the screen is changed the line will sometimes go away momentarily and then come right back. Any ideas?
Anonymous
Level 2:
  • Expert 66 Answers
  • Posted on Oct 30, 2009
Anonymous
Expert
Level 2:
Answers
66
Questions
0
Helped
26458
Points
166
Replace the lcd
Testimonial: "Solved the problem "
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
My Toshiba A135-4527 makes a clicking noise when I turn it on and keeps restarting a at the Intel Corporation screen. There is also a red line down the left hand side of the laptop screen.
Sounds like you have two problems, first! the hard drive is probably gone bad, second! the LCD screen is suspect, try hooking up a computer monitor on the the video output located on the back of your Laptop, if it produces a clean signal you know there is a Laptop screen issue.
Please, I need instructions on how to replace the screen for my Toshiba Satellite A135-S4427. Thank you.
do a search about "screen replacement" or "laptop repair" in youtube. I've seen many videos about computer repair in there
Blue screen-Toshiba A135-S4427
the ram memory must be sufficient about 2GB & the processor must be dual core or core 2 duo.
if both condition your laptop follow then i think you should scan your lap top with anti virus.
Toshiba Satellite A135-S4427 Frozen
there is problem with the mother board try repairing at repair shop
10helpful
4answers
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
3helpful
2answers
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
9helpful
LCD TV - RED LINE
I have a thin red vertical line on the left side of my Philips LCD TV
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
