When you use your self clean feature, your oven heats up to over 800 degrees and this normally takes your electronic computer control board out.
I would first check the elements and thermal fuses of the oven. Verify that these parts have continuity. ( See videos -- https://www.repairclinic.com/Video/Video-Landing/569-/Oven-Won-t-Heat-Thermal-Fuse-Test-Gas-Electric-Oven-Repair and https://www.youtube.com/watch?v=X8w1w45TrnU ) If all of those components are good, then the control board is likely the culprit. http://www.fixyourboard.com Can remanufacture your no longer available control board. We also back our workmanship on our rebuilt boards for 2 years. ( the best in the industry! ) If you end up needing a touchpad/keypad too, they have those as well ! Contact us at 512-355-1108 or [email protected] for help!
Recently replaced control panel. Now only clock is on, however, none of the buttons are working. So can't adjust time or even turn in oven or timer etc.
