Kitchenaid side by side is freezing food in the refrigerator section. I replaced both thermostats under the suggestion of a repair shop and it did absolutely nothing.
no vents are blocked by food.
the refrigerator freezes independent of temperature setting (tried 1, 2, 3, and 4).
The refrigerator is usually partially full.
SOURCE: Refrigerator section warm. Freezer section OK.
Most likely it's a defrost system problem. One of the heaters could be bad and that will cause the coils to freeze up reducing the amount of cold air the fan can push into the fridge. Sounds wierd but, trust me, that could be your problem. Mine did that two years ago.
SOURCE: food freezing in the refrigerator side
hi! you already the solution of the food freezing problem.the cause was occurs because the thermostat was not duly calibrated..it recommended for calibration.
SOURCE: the refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
SOURCE: build in kitchenaid, freezer working but not freezing
sounds like you nave a freon shortage or a restriction
