Toshiba 32 AV 500 PG 82cm 32 in. LCD TV Logo
Anonymous Posted on Oct 19, 2009
Toshiba Big Screen Tv Has Bad Colors
Hi I have a big screen tv toshiba which recently show double but i try to fix the convergence in the tvs Menu But now it shows a clear image but the only color is a light purple . Also the convergence did not work totally cause you can still see the double image a little.I dont know if the bad convergence affect the colors and if i need to open the tv But Please Help Need The Tv For A Game Please Help and also the tv is not a 32 av 500 pg 82 cm 32 inch lcd tv, its just that i dont know what model it is
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
3624
Points
31
This is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Testimonial: "Thankx Alot Man"
Hey there recently my screen just went haywire and i am seeing double and the second picture is red in colour,also the bottom of the screen is curved....what causes this and is it worth fixing?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
"touch focus error" appears when the test is completed. There is a double effect showing on the pictures and the words. What can be done to fix this?
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
My big screen tv looks 3d and red green blue are off
  • Screen looks 3D
1helpful
2answers
I have a 52' big screen and the picture is shoing
Ur convergence is dead,go to ebay.com buy the convergence repair kit.Find out ur make and models,and manufactures of ur TV buy it.
All big projection DLP have this prob. one time or other every manufactures,Sony,Samsung,RCA,many others.
Blurry pic double pic
  • Screen looks 3D
1helpful
My tv is showing a double picture in red its showing double in red
  • Screen looks 3D
Mitsubishi 290p080020 big screen tv
•Screen looks 3D
2helpful
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
