Hp 3500 that wont print the black it prints the outline of the black but you cant make it out , colour seems to print fine on the config page but hardly no black
None of the cartridges can be empty if you want to print. Even if you only want to print black, just black you need to replace the other three cartridges. Yes color laser printing is expensive.
Some printers offer the option of printing in Black only in Preferences so you could try that. Another choice is to remove and reinstall the cartridge as sometimes it will reset. If your black cartridge is empty, the color cartridge can print black for awhile but it is probably more expensive per page to do it that way. If the color cartridge is empty, then it would be probably cheaper to print from only it.
You could also inject so ink with a needle into the empty cartridge then set your printer to not use that cartridge but this can make a mess unless you know how to refill cartridges at home.
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
You can't print anything unless all your toners are in the printer and NONE of them are empty. I understand what you are trying to do, but it won't work.
If you go to control panel, printers and fax, right click on your printer, then select properties you will see a section for color or grayscale printing. Select grayscale for all your jobs to be printed in B&W.
defective cartridge or problem whit laser/scaner assy
- replace cartridge ( to solve this just turn back your old cartridge and try to print something to be sure before you buy new one)
- visit HP servise for laser/scanner assy
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
