Astoria Divina SAE-1 Espresso Machine Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Astoria cke 1 group coffee machine ware is the water hose connector / inlet ?
Ernest R
Level 3:
  • Master 1,618 Answers
  • Posted on Oct 20, 2009
Ernest R
Master
Level 3:
Answers
1618
Questions
0
Helped
730024
Points
3103
Bottom of machine under the draintray, follow the manual fill that sticks out the front bottom.
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
I have a Astoria Argenta and one of the groups is not working. If there is a blockage, how do i get to the problem.
basicaly all you can do is unplug machine, turn off the water and cool machine to cold. then take apart the group head working back to the boiler till you find the blockage.
2helpful
Hello. No water comes from coffee dosing, the led is blinking (san marino ckxe coffeeemachine), but the pump is working
Remove the shower screen and try again if that does work then the machine is blocked at the top of the group (Big nut on top front) in the metering jet.
Hi, I have the astoria jada ak super automatic. I
The drain **** is either blocked or bend or is making a big bend which is blocking water in it a this making dificult for the drain water to flow. Their is also a smal chance the main drain pipe to be blocked so you can try to put the drain hose inside a bucket to check if the water can run through you drain hose
I have an Astra Mega I single group espresso machine 110v. I seem to not be getting enough water through the portafilter and it is all clean.
Remove portafilter, shower and screw and run the head. Did you get a nice steady flow or a weak drip. If a weak drip then the solenoid or the metering jet on the head is blocked and needs to be cleaned. If you get a nice flow the adjust the grind on the coffee to coarser.
Astoria Espresso machine not grinding espresso beans in the 2nd group
Every group have a water jet of about 0.8 mm probably blocked or the jet filter. You should descale the filter and jet
Pump nt working proper.y
Check the auto level probe and box, also check the inlet solenoid, one of these three are not functioning.
Water still following from the right dispence
The coffee solenoid valve which is located on the coffee group is having a dirt which is keeping it always open and the water is direct with the mains on this valve so you have continuing water out from the group head. You have to close the water mains valve to stop this. Remove valve and clean it. Dry coffee on the valve can cause also the same problem so clean the valve.
Please remebr to vote for this answer thanks
I need a new pressure guage for an Astoria A2 - coffee machine
here is the site where you can get your presure gauge and other parts for your machine.http://www.espressoparts.com/results.cgis?catalog=&select=NAME&keywords=astoria+pressure+gauge&image.x=15&image.y=14
Top Astoria Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
john h
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
