This is a rare problem...you can fix your error using wii repair guide...for further help click here
Here are few Home remedies that should help you fix the issue.If you still face any problems then it is an internal issue with your remote and you will have to contact the nintendo support.
Re-sync the Wii remote to the Wii system:
Operate the Wii remote between three to eight feet away from the sensor. Otherwise, it will not perform properly.
Note
that infra-red lights from candles, toys, appliances, fireplaces and
even sunlight may effect how the Wii remote performs. Try to remove or
reduce infra-red interference from these sources when possible.
Turn
off or move wireless devices located near the Wii console. You may be
experiencing radio frequency interference from other wireless devices.
Thank You
Push
the power button to turn on the Wii console. After the health and
safety screen appears, open the small door on the front of the Wii
console. Locate the red SYNC button. Push down on the SYNC button for
fifteen seconds. This resets all previous SYNCS on the Wii system.
Re-sync
the Wii remote. Locate the red button on the remote control under the
battery cover. Push and release this red button. The Wii remote should
respond with blinking blue lights.
Push
and release the red SYNC button on the Wii console. Place the batteries
back in the remote. When the remote is successfully re-synced, the LED
light will remain lit.
Repeat the re-syncing process with all other Wii remotes on this system.
Wii U
