I have a fisher & paykel smart drive 601, I haven't used it for a while because I got given a front loader, it worked fine when I put it in storage. Took it to the parents house and plugged it all in and now it has power on the board, you can set the program, but it doesn't let any water in or seem to start the cycle.
If it isn/t doing anything at all it could be a faulty start switch on the display panel. Also make sure you can hear an audible click when you open and close the lid. The lid switch on a 601 is actuated on the right hand back of lid adjust as required. Hope this helps.
Testimonial: "Thanks I will try that!!!!"
If it doesnt fill it wont do anything unless you switch it to perform another function such as spin.
Check the water valves for blockage. Select Warm wash instead of Cold so that both valves are actuated.
If nothing happens, the panel may have to be replaced.
