For Behringer B300..... where is the ic 7815 and 7915 located, are they labeled and are they soldered in or plugged in? my unit pops out to overload constantly ...can an amateur fix this?
thanks
Test the regulator chips FIRST before ANY replacement. These chips are very reliable and the problem is LIKELY elsewhere.
The 7815 and 7915 ar 15 volt three terminal regulators in TO220 style packages. Three leads. The 7815 is plus 15 and the 7915 is minus 15.
CAREFUL as the input and ground pins are in different order between the two.
FIND the specs and picture with Googling the numbers.
These chips will be soldered in AND MAY be screwed or clamped to a heatsink OR just standing up from the board.
Testimonial: "fredy2 sounds like a good approach /////thanks"
Often they are close to an internal fuse. A thermal fuse, nog a normal one, just like the 7824 and 7924... which probably also is on your board.
