If you are also using a Cable Box, make sure that the zoom selection, (Format) ,on the Cable Box remote is set properly. Especially if the TV Remotes Aspect Ratio is set to a Wide Format.
Hope this helps,
Skyassoc
This is the same problem I have (the picture being cut off on the edges). On your computer, you need to change to a native display.
For instance, 1920x1080 usually cuts an inch off of all sides, but it's meant more for videos where a little cropping isn't a big deal; not general screen use.
I believe the reason this happens is because with those other resolutions, 1920x1080 for instance, they are not your laptop's "native resolution", so in order to avoid scaling and stretching the image (which would degrade quality) they show its exact size, point by point, which is bigger than the number of pixels on your TV display.
Some TVs, like mine, have a TV option called "100% scale" that forces the picture to exactly fit to the screen. But this causes stretching and distortion if the aspect ratio of your resolution and the TV's whole screen are different.
Try something like 1366x768 or 1360x768 (some have both, some have only one of those). You should be able to find one or two resolutions like this that show the entire screen with full sharp clarity. It may even look better than 1920x1080 depending on your computer; find the best one that shows sharpness.
When the picture is too large there are three possible solutions at least.
Starting with the simplest two: There are buttons on the remote controls (cable/satellite and television) that control the picture size. On the cable remote it is usually on the bottom, and it says hd zoom. Press it and it will size the picture down for you. On the television or satellite remote it might say view mode, picture mode, format or aspect.
Now, the more difficult solution if the above doesn't work: The settings might not be right in the cable box/set top box. If the television is a 720p television, make sure the cable box/set top box is set for 720p and not 1080i even though they're the same (yes, yes I know). Also make sure you are not connecting a cable/set top box to the coaxial rf input when you have the capability to connect to a component or hdmi cable. I hope this helps.
First the picture size is probably related to the screen resolution or aspect ratio. In Windows 7, you can adjust the resolution by right clicking on the desktop and choosing Screen Resolution. Make sure you do not exceed the limits of the video graphics output of the laptop or the refresh and resolution of the TV. (Without knowing your hardware, I can't tell you the actual settings you should use.) Usually HD TVs are either 720p or 1080i. Alternatively, check if you can change the zoom or aspect ratio (4:3, 16:9) on the TV. Those settings may fill your screen. (It could expand the image past the viewable edges of the TV or distort your image though.)
For the audio, you should check the Sound outputs. Again in Windows 7, click Start > Control Panel > Hardware and Sound > Manage Audio Devices. Under Playback, see if you have an option for HDMI sound. If you don't have this option, you will need to connect an audio cable between your computer and TV. (If the TV has a VGA input with a PC audio jack, use a 3.5 mm audio patch cable. Otherwise, you'll need a 3.5 mm to RCA audio adapter or cable.) Make sure that the audio isn't muted.
If you have a different OS, the specific commands will be slightly different but similar in Windows.
either your TV or your cable/sat box(if any) is on zoom(enlarging pix). Look for buttons on both remotes that might say picture size or aspect something like that...Pressing these buttons usually cycle thru 3 or 4 size options. When in zoom center of screen is the focus and outer edges of pic are cut off.
It's one or two problems. It depends on if you're using a cable box. First try to see if your aspect ratio is on full using the JVC remote. Just Press the Aspect button. Then if it's on full and this doesn't correct the problem it may be your cable box. If it's time Warner go into the settings by pressing the settings button on the remote twice I believe tehn go to display and select the select and check each option picture size (change to normal if you have a 4:3 t.v. or stretch if you have a 16:9 (wide screen T.V.) Then go to aspect ratio and select again eih 4:3 or 16:9. If your have a hdtv cable box select output resolution and make sure there is a bulllet next to each setting for 480i, 480p, 720p and 1080i. Then exit out of the cable settings and your picture should be ok. Now if you have the hdtv package keep in mind it is normal to have the black side bars on each side of the picture only if your watching one ofthe high definition channel network that is not actual being broadcast in hdtv or recorded in hdtv.
That is because you are watching the picture in the 4:3 aspect ratio. This is normal when you are watching a channel that is being broadcast in 480 or digital. But once you tune to a station that has 1080 or at least 720p which is true high def then the picture should expand to 16:9 aspect ratio. It will switch between the two automatically as it determines what type of signal it sees. You can force the resolution to change by pushing the format or aspect ratio button on the remote but you will lose picture quality.
Your screen somehow got switched to theatre/cinema mode. There is a setting on the remote that attributes to aspect ratio. Sometimes it is called "ASPECT". Look for it, and press it until your original screen aspect shows.
Your digital box should have aspect settings as well. When watching HD TV and or movies there is a possibility to get the black bars on top and bottom. It all depends on the ratio it was filmed in.
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
